Dan Whitaker said:This one should realy scare you. My dad was a mechanic at a TOYOTA dealer from 1971-mid 80's before fuel injetion was around. What they used to do was mix water and automotic transmission fluid and pour it down the carb while it was running and keep it reved between 2500-3000 rpm to keep the engine from stalling.
Mbrooks420 said:No interest in using the brake booster, I want to foam all the cylinders, or it's not worth it. I'll search around the coil packs and see what I can find.
I didn't know you were supposed to spray the Deep Creep with it running ... I use it as WD40thekubiaks said:Cut me some slack please, some of you are talking about spraying deep creep into the intake. Are you spraying the deep creep into the intake at the MAF or where exactly are you spraying the stuff??? If I spray this stuff at the throttle plate, will I pop MAF codes?? Thanks
Spdrcer34 said:thekubiaks:
Now you need to go back and do it the RIGHT WAY.
Use the vacuum line on the throttle body. That way you'll get all the cylinders.
Ryan
