jremington59
- October 28, 2009
- Watertown, NY
- 1997, 99 and 2000 5.0's
The outer tie rods are adjusted for the toe.
Did they suggest changing the bolts for camber and castor? Also, if either tie rods were bad they should have told you prior to alignment. But if they're right they may have found the cause of the shaking. If one's shot and they are original I'd do all four and get it out of the way.
