sehaare
- October 25, 2008
- Chicagoland, IL
- 98XLT 4WD SOHC,94XLT gone
98 XLT SOHC 4DR 4WD
I've read through the other treads and most of them just end without a resolution. Here is my issue:
I was refurbishing the entire front end suspension and steering. I had replaced both upper control arm, but lower control arms, sway bar bushing and liinks. shop had replaced one inner tie rods and I have replace the other and both outer tie rods. While I had the front end up on jackstands I noticed that both tires can be moved somewhat before the rack and the other tire starts to move.
I thought that it might be a bad wheel hubs but today when I put it up again there was no up down motion only side to side, so I figure that rules out wheel hub bearings.
So now I'm wondering if I'm over reacting. Is there supposed to be a little slop with inner tie rods? or are both inner tie rods bad (I doubt that), or is it the steering rack?
XLT came back last time aligned fine and drives straight.
I'm trying to get this all figured out before I go off on a work trip for 4 months and leave the XLT home for my daughter.
As Always thanks in advance for any advice.
