Thanks!
So time for the lower radiator shroud.
And then I said hey,
what a wonderful kind of day, if we can learn to work and play, and get along with each other. Wait, thats from Arthur (thats PBS - for the newbs). So i said hey, lets break out ye old composite technique and see whats up. So I made a wireframe for the radiator's main shroud from 1/8" steel rods:
Got it all taped up (epoxy resin doesnt stick to packaging tape), and proceeded to lay down a layer of fiberglass and then carbon fiber. Unfortunately, the resin I used was just absolute crap (the type from car stores - Pep Boys). The resin would not set correctly -- cured fiberglass strands should cut into your skin once properly cured but this particular resin remained soft and the fiberglass would not penetrate my skin (after 24 hrs of cure time). Fortunately, there's a West Marine 20 mins away and I went with a gallon of West System and taped up the wireframe again. Unnnnfortunately, I wasted most of what little carbon I had left on that POS resin. Oh and the tape was "heat shrunk" with a heat gun.
So I only had a tinsy bit of carbon left so I used that on the perimeter. I ordered more but it probably wont be here till sometime this week. But anyways, here is what I had this afternoon with a few layers of fiberglass and a bit of balsa as a core material to provide some more rigidity.
But in hindsight (it wears corrective contact lenses), I came back home tonight, felt the results and I dont think I needed the balsa - the surface feels nice and firm even with just the fiberglass. But I think I will lay down one layer of carbon (as soon as that material arrives) just to be on the safe side.
