JMan689
- August 4, 2006
- Downers Grove, IL
- '14 Focus ST
Okay you clowns .. some useful stuff:
Chevy S-10 extended cab two piece driveshaft plans:
This driveshaft comes with 1330 u-joints in a Saginaw configuration, ends will be converted to 1310 (compatibility with the transfer case's front output yoke). 1330 double cardan has a max of just over 20 degrees -- not enough. This one measures to a max of 27.6-4.3 ... about 23 degrees.
Triangular calculations using the 14" shock says that at full droop, the driveshaft angle should be around this 23 degrees figure. So the goal is to increase this angle by grinding down some of the double cardan parts (primarily the weld yoke on the tube side). The goal is to get it around 27 degrees.
The rear will also be a double cardan but unfortunately, the angle in the rear is greater than the front. So I might have to switch to 1410 which maxes out at a healthy 37 degrees.
I think you need to come out here and do all the calculations for my SAS
