Speed Governor | Ford Explorer Forums
Speed Governor
niblickgolf7
ILLINOIS
Explorer '99 Eddie Bauer
Hey whats up everyone. Does everyone knwo where the speed governor is on the 1999 Ford Explorer and do any of you know how to take it off.:exp:
Appreciate your helps thanks
niblickgolf7
To change/remove the speed limiter, one needs a chip/tune; iys PCM controlled.
Al is 100 percent correct, and I build on this subject, as i am in the process.
Along with setting or eliminating the speed limiter, a good tune will adjust rev limiter, shift points, air-fuel ratio and ignition timing curves for more efficiency, more performance, or you can even install a slower speed governer ,good for anti theft-valet-letting kids drive car, if a piggy back flip chip setup is used. Hide the switch.
