learned a few more things today
they are the same, so no need to change the cross members
and just like simon said, the cruise control cables are not only longer, but the ends are different to. didnt realize that one.
so i was fighting with the rad and condenser yesterday, and was not having any fun doing it either. i i had called simon to ask if he had the same problem. well not thinking his body lift gave him his own set of problems, as we talked about it, he had mentioned, and i was also thinking the rads for both 4L and 5L are the same (width height, length, and tube placement). what i wasnt sure about (and i cant remember if he had said or not) was if the condenser was different or not. seeing i screwed evils rad up (drank **** broke, and i had to drill threw the drain to empty the rad, thus also making a pin hole in the perfectly good rad, DUHO!) i used the 5L rad, and the 4L condenser. the difference is, on a 4L set up (or at least evils) the condenser is bolted to the rad support, on a 5L it is clamped on to the rad. low and behold, it went in with no problems (both are 2 core mind you, take that as a note). also, the upper part of the air filter box is the same for both 4L and 5L are the same (panel filter, not sure about a cone style filter). i was happy cause i can still use my K&N.
then the next headache. when i went to connect the bulk connector to the motor (the one that clips on top of the valve cover for a 4L) it was about 2 inches to short. number umpteenth question for both simon, and russ. russ told me when they did the rock trac it was tight but with the body lift, it may have helped a bit. simon said he cut back some of the tape, stretched it, retaped it, and all was well (pickle also has a body lift). evil.......well, that was fun.
what you are looking at is the the harness that goes under the power distribution box. there is a bolt that hold it into place (if you look to the right you can see the hole). i took the bracket off for the box, unbolted the harness from the fender apron, as well as there is a push clip under that battery box that i unclipped. pull the harness towards the fire wall, then outward towards the motor. you can still bolt the bracket for the power distribution box back in, but the harness will be resting right beside it. that gave me enough slack to bolt the bulk connector together. i may one day make a jumper harness, but that will be later.....maybe.
dont really like it, but it will have to do for now. it was this, or use the complete v8 under hood harness, but i really didnt want to unclip everything. that and i have added some wiring of my own under the hood, and did such a good job at it (or in my opinion) that i cant tell whats what!
also another thing i learned today.
see anything wrong with this picture? i didnt either for the last 4 months until i tried putting the cables on......its on the wrong way
took me a hour to figure that one out.......
so today's progress you ask (i knew you would ask)....
with the exception of the battery clamps, repin the one connector, and solder two other wires together, MOTOR IS TOGETHER!!!!!!
*happy dance, happy dance!* hopefully i can get by buddy to change the rear main seal for me (he hasnt been able to give me a hand with anything yet, but hey its new years so i dont expect to much from him). i dont trust myself to do that, and really dont want to do it and find out when its too late that i scaruuuuude it up either. if that gets done, then the trans goes in, and on to fitting the 4406.
side note. all that money for them, bob dose such a nice job making them.....an you can hardly see them....the headers that is
who me stressed???? naaaaaaaaaaaaaaaw
