Silver X
- October 27, 2002
- Brownstown Twp, MI
- '01 Sport 4x4
WTF? How many different variations of 5R55E 4x4 transmissions are there?
I'm in the middle of replacing the trans in my '01 Sport 4x4. I got another 5R55E out of an '01 Explorer 4x4 with a 4.0L SOHC (probably 4dr) from a junk yard going out of business. I made sure the replacement trans was from an '01 with low mileage to try to minimize the chance of problems!
I got it into the truck and bolted everything up. Went to hook up the wiring harness, but there was an extra connector hanging from the truck. Looked at the old trans and found an extra sensor on the drivers side near the middle of the case. I'm guessing its a VSS or something. The new trans has the boss on the side, but isn't machined for the sensor.
So I had to remove everything again and need to figure out what to do.
The reason for replacing the old trans is because it started pouring trans fluid out the front of the bellhousing whenever the truck was running. I'm thinking blown pump seal. The torque convertor was also shot for a long time before that. Truck wouldn't start moving until 3k rpm and convertor wouldn't lock up when cruising. The trans also had the 2-3 flare again. It has been rebuilt twice already, so I wanted to start fresh.
Since the new one is mostly the same and has extremely low miles (11k miles), can I just use some of it's parts to fix my original one (103k miles)? I'm hoping to swap over the valve body, pump, and convertor from the new trans. Should I mess with anything else? Would I need to change anything else? I know there are some differences inside, but not sure what. I really don't want to get too deep into it, since I've never messed with an auto trans before.
If I should just find yet another trans, what models of Explorer have what I need? Is the '01+ Sport/Sport Trac 4x4 trans unique? Is it shared with the '01+ 4.0L SOHC Ranger 4x4? This is extremely frustrating!
