That's ok, they bent the tubes to match your vision
Who makes the pro racer software you are looking into?
SCT makes it. Big for me since it will work with the hand held I have.
Ive heard through the grate vine that James isnt doing tuning anymore..or least not remote
James is still doing remote tunes I have been in e-mail contact with him.
He's been really slow and short/vauge with replies. I don't know if he's just that busy or isnt interested in my business that much...Just seems in my opinion to be unwilling to work with my setup. More specifically, he prefers a lot of things a lot of ways that dont seem necessary/practical to me for my build.
I'm not going for maximum horse power on my build or looking to build a race car here I just need my system to support my build looking at it holistically, it does.
I'm working with limitations and contraints (snorkel, space, etc.) that make a few things like a 3+ inch intake pipe and 42 lb injectors impractical for my build. Im rich across the rpm range right now no more lean at 15-16 for an AFR and 19-21 AFR at idle theres enough fuel available with 36lb injectors. I see 12.5 on start up and it slowly begins to lean out a little closer to stoichiometric afr. There's plenty of air getting in to build boost and add a noticible amount of power even drawing through my snorkel and blowing through a 2.5" pipe. It's the same size as the throttle body and so far it all works fine for me...if someone can explain to me with a logical fact based explanation why these won't work I'll reconsider but I'm not trying to build 300hp on stock heads, cam, pistons, rods, valves, springs, etc. with a 19+ yr old ohv on an m5od... Probably between 200-250 if I could guess...
Another reason I'm thinking I just buy the software and educate myself. If I do decide to make future modifications I can retune with what I would have instead of paying another wad of cash to retune again and I can fine tune as required for whatever conditions or tweaks I may want to no added cost, no middleman and I'll become that much more self reliant and familiar with my vehicle. A lot of benefits.
all I need is the software. I have everything else except a dyno...which I dont think is necessary to find a place with one. I'm able to data log under real conditions on the Hwy, Low range off road, that's what I need. Not WOT 5k + RPM. I don't drive like that.
Con: I dont have the experience so there may be some trial and error/added time.
Maybe I'm convincing myself but it seems like a worth while investment for my off road fun/hobby (you could probably call it that)
