- June 16, 2003
- Humboldt, KS
- 2000 Mounty
I have 2 cylinder head temperature gauges installed in a dash pod. The senders are located in the rear head bosses--against the firewall. They are located as such that to get to them requires pulling the engine, I do think
In fact, I had bumped the passenger side sender against the fiirewall when I installed the engine and always suspected it, as it read about 5 degrees higher than the driver side .
Now, today, out of the blue--
Idiot gauge in cluster reads as normal, just into the n range. Driver head reads 170 or so, but the right side reads 220, maybe even higher.
So, When I returned from the 25 mile round trip, I let the engine cool and started it gain to observe the gauges from a cold start.
Just as soon as the driver side gets a reading,150 or so, the passenger side is shooting up to 190.
I have an infrared handheld thermometer, where should I point it for a reading to compare temps from bank to bank, without header temps interfering with my reading?
Or do you have a better suggestion for troubleshooting this??
I almost wish I didn't have these gauges now--
