Temperature sensor o-ring size | Ford Explorer Forums - Serious Explorations
Lukas2009
Cologne
2007 Eddie Bauer V6
Got my new temperature sensor today and measured the o-ring:
Outer diameter: 13.5 mm
Inner diameter: 8.5 mm
Thickness: 2.5 mm
Fits perfect into the new thermostat housing.
So I think that the o-rings from home depot which were suggested in another forum by mdisalvo will also fit, because in the result they have nearly the same size (as described on the package):
Outer diameter 9/16" (14.29 mm)
Inner diameter: 3/8" (9.53 mm)
Thickness: 3/32" (2.39 mm)
