Thermostat housing leak | Ford Explorer - Ford Ranger Forums - Serious Explorations
efiles123
1999 Explorer
I have a 1999 explorer 4.0l that has been loosing coolant. I recently noticed a small leak around the thermostat housing as shown in the pic. My question is should I try replacing oring or just replace the entire kit? The current thermostat is the second replacement.
fast_dave
East Bay - Nor Cal / PRK
'98 Spt 4.0 OHV 5 spd 4x4
From the pics, my vote is at minimum another $20 Plastic Kit from Amazon = 1 & Done
The SOHC diehards will advise you to upgrade to the Aluminum Kit for $40 more ($60 TOTAL), and that's fine by me as well if you have the $ for it.
XLTrunner
MN
1998 Explorer XLT 4.0SOHC
Depends on how much enjoyment you get out of fussing with these. I'm on my third one...and, next one (if there is a next one) will be the aluminum housing. My biggest pet peeve (beside the horse-s**t design of these plastic housings) performing this job is having to remove the alternator, alternator mtg brkt, and belt tensioner to access and loosen the crank position sensor harness that is draped snugly over the middle of the t-stat housing preventing it from being lifted upwards during removal.
efiles123
1999 Explorer
Thanks for the responses guys. I’ll have to go with replacing the entire housing. Gonna see what the local parts store has in stock.
fast_dave
Just sayin' - the local parts store will more than likely be twice the price (of Amazon) on Plastic.
Keep in mind, at that point, you will be only $20 away from online ordering Aluminum, which seems to be the overall best solution.
donalds
Location
Stem
Nc
1999 ford explorer sohc
My aluminum one is mint put it on and never messed with it yet
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
fast_dave
^^^^^ Some good info there!
efiles123
1999 Explorer
Ok I think you guys have me sold on an aluminum one. Is there a specific brand you recommend? Just went on eBay to find several and have no idea what to get or stay away from.
donalds
Location
Stem
Nc
Mr. Alligator
Tampa, Florida
1997 XLT Explorer
Aluminum. Simmons.
No more problems (with that….)
Good luck.
efiles123
1999 Explorer
Simmons SimmonsAutosportz
Or
the one on eBay is for 01-11 and I have a 1999 which says not compatible in the ad. Also tried Amazon and google without any luck. Has anyone had good luck with Osias or other aluminum rands on eBay. Says they offer 2 year warranty.
donalds
Location
Stem
Nc
It fits my 99
You can reuse your plastic outlet .....top piece..... I did not
The Simmons one
You can call them
Here is it on my 99
