1998rollover
- November 10, 2008
- Weiser, ID
- 1998 Mountaineer
How would you see that contamination if you don't remove those bolts?
I think that avoiding maintenance because of that reason is dangerous. I always remove those bolts to lubricate the sliding pins, put them back tight and, in 20 years, never had one backing out. Never used blue locktite either. Probably most of the people that complained used either lubricant or anti-seize on those bolts.
On the other hand I saw pins that didn't get serviced in 10 years and the baked grease was caused pads to drag and overheat the whole caliper... leading eventually to leaks at the cylinder gasket.
I put new pads on an F350 last week. Same four wheel disc setup as the Ranger/Explorer/Mountaineer, but larger. On the right side, one slider pin in each caliper was seized. I took them out, cleaned them, applied the proper grease and put them back in.
Now that the brakes are 100% on both sides of the truck, it stops really well. The trailer brake control had to be cut back quite a bit to keep the trailer brakes from locking now that the truck takes more of the load.
I use a 14" long SK 1/2" drive ratchet and put a lot of force on the bracket bolts when they've been removed. Haven't had any come loose yet.
I also have a 17" long Titan 3/8" drive ratchet that is NOT a swivel head. I got it at an automotive paint supplies store. Dunno WTH such a place had tools for sale but when I saw that I said "Merry Christmas!" grabbed it and eagerly smacked the $25 on the counter.
What the #$#%@# took a tool company so bleeping long to make an extra long NON-SWIVEL 3/8" ratchet? I use that ratchet so much, it's smaller head gets into places no 1/2" one can and with its length can bust loose bolts and nuts in those nearly inaccessible places.
