- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
the cab cage gets bolted the the floor yes, but on the other side of the floor it also gets welded to the frame. The body becomes one with the frame. You can bolt through the floor, look at Rookie's build on his BII.
I plan a full cage, cab and seats tied into the frame for sure.
I think of places like POtato Salad hill and Lionsback when I think cage, where if you roll once you could be going over a few more times.
I plan to tuck the cage up to the sheet metal as much as possible, so if it does get crsuhed in a corner the piece can be cut and a new peice welded in. Keeping the body damage "contained" if you will.
