I agree. 35psi is the max pressure rating for the 105S tire. This pressure is where the max load rating is rated. If you are hauling or towing a heavy load, 35psi would be recommended. I run 32psi and am happy with the ride.
I hauled a load of firewood both in the back of my Explorer and in a small utility trailer. At 32psi the tires showed no sign of squat. They didn't appear to even see the load on them. In fact the rear (ground to rear wheel fender) of my Explorer came up almost 2 inches after I unloaded the firewood from the back. The before and after measurement was after the trailer was unhitched, so the 2 in change was just the wood in the rear cargo area. I was pulling in late afternoon and in one area the outside temp got to 100 degree. It was about a 200 mile trip home loaded (with wood that is). One stop for a late lunch. When I got home all 4 truck tires were the same temp to touch. Before with the Firestones, the rear tires usually were hotter than the front and this was without a load.
Needless to say, I love my Michelin LTX A/T's and 32psi would be my recommendation for all-round use except for that extreme occasion.
