mlmaher
- June 7, 2007
- Aurora,IL
- 2002 Sport
So I am trying to reinstall my torsion bar on my 02 explorer sport. Replaced upper ball joint, lower control arm and ball joint, tie rod end sway bar links shock all on the passenger side. My problem is I can not get the torsion bar adjuster screw and nut plate back in its slot. I am using a 5 ton gear puller to tension the torsion bar. However it seems to me that the adjuster insulator plate is shifting IB towards the center of the vehicle preventing the adjuster from properly lining up with the slot for me to insert the nut plate and torsion adjusting screw. Anyone else run into this? I haven't seen anyone mention this. I just ordered a new insulator plate perhaps it is worn enough to cause my problem. Thanks:yelexp:
