DFully
- April 9, 2021
- Willow Creek, California
- 2006 4.6L Eddie Bauer
I own a 2006 4.6L 3 Valve explorer with the 6R60 transmission, recently my radiator cracked along the top of the plastic causing a substantial leak. Now radiators are sold out ado the wait time is pretty good amount of time not having any wheels. I unfortunately could not wait the required time to stick with the Motorcraft radiator so instead I ordered the mishimoto OEM direct replacement with the lifetime warranty. I’ve used the warranty once already due to the shipping being so roughly handled the radiator was bent and leaked out before I even installed it so I waited another 3 weeks to get the replacement and after installing it everything was great ran good as new but after a few hundred miles I noticed a fairly small leak, I investigated further and I soon found out the leak was no longer a small one but a rather moderate and growing one. The leak I was able to diagnose as the transmission cooler line connector on the driver side was the culprit and after some research I found that the mishimoto radiators use the same cheap connectors as most of the non Motorcraft radiators use with only one o-ring located inside rather than two.
My question is if I buy the dorman replacement will the thread size fit the mishimoto or how do I fix this dilemma? And to flush the intercooler what all is required since I’ll have to drain both coolant and the intercooler in order to properly install the dorman replacement?
