In the mud and sand settings it acts like a 4WD Hi setting. Not sure why (besides marketing) they put the 4WD emblem on the back. I also think an AWD emblem would be more accurate.
Here is something cool you guys may not be aware of on your AWD,4WD new explorers. If you switch your 4inch left hand dash display to the intellegent
4WD graphic you have the ability to see exactly what your 4wd system is doing it real time. It shows you where the power is being applied to the wheels when you accelerate or loose grip on snow or ice. You can see what happens when you switch modes from snow or sand for instance. It shows the amount of power or torque going to the front or rear tires.
It is pretty cool to see how the power and traction is shifted to the rear wheels when accelerating from a stop on snow or ice and than once traction is regained it transfers power back to the front wheels.
The graphic display gives me confidence that the intellegent terrain management system is indeed working the way ford has designed it to. It is a great feature for ford to have added to this vehicle.
Some guy was trying to tell me that the new explorer is awd. True? False? Is this thing 4 wheel drive?
Hey jakefeb3,
This is Seni with Ford Customer Service again. The Explorer comes standard in FWD and offers Intelligent 4WD. Intelligent 4WD is fully automatic, instantly delivers traction to the wheels with the most traction when wheelslip is detected. The 4WD System also works with the Terrain Management System, which allows you to easily shift into one of four settings (normal, mud/ruts, sand, or grass/gravel/snow) to match the terrain you’re driving in. For more information on this system, check out this web site http://www.ford.com/suvs/explorer/features/#page=Feature3. Let me know if there is anything else I can help you with.
Seni
Seni - so one clarifying question by someone who is finalizing their choice between the Flex and Explorer. The system on the Explorer will automatically distribute power to all four wheels, regardless of the Terrain Management System setting?
So. Umm. I think there are 4 of you that say this is AWD? But I think Seni is saying that it is still technically 4WD? And the reason for it still technically being 4WD is because it can switch from a 2 wheel operation, to a 4 wheel operation? Am I reading this correctly? I was hoping for this vehicle to truely be 4WD. I understand it does not have the extra low gears that 4WD vehicles normally have.
okay. I accept. This is slightly more comforting. Last question: I would enjoy if you could give me a "yes", or "no" on this:
The 2011 ford edge comes with an option for : "active all-wheel drive"
the 2011 ford explorer comes with an option for: "intelligent 4wd"
generally speaking, and mechanically speaking: Are these 2 systems completely different?
Just in case you think you have it figured out. My Highlander has power going to all wheels full time. Split 50-50 front and rear. The emblem on the back says 4WD
On another point, with those 20" Hankooks it doesn't seem to really matter. Unless the road is bare, dry and warm, you'll likely be spinning your wheels anyway!
Okay. I accept. This is slightly more comforting. Last question: I would enjoy if you could give me a "yes", or "no" on this:
The 2011 ford Edge comes with an option for : "Active All-Wheel Drive"
The 2011 ford Explorer comes with an option for: "Intelligent 4WD"
Generally speaking, and mechanically speaking: Are these 2 systems completely different?
