I'll do that today and see what happens. I also noticed last night that when i had my uncle turn the wheel hard back and forth while I tried to find anything that is loose or moving that the tie rod bar that goes from tire to tire twists. because I am running the 1 ton TRE's and the drag link hooks to the one tre as it pushes and pulls it twists the tie rod. And since both ends of the tie rod are level with each other the tie rod twists the full amount of what the ball and sockets allow. That is the ONLY thing I found everything else is very tight no movement any where. So maybe when the tires are at speed its pushing and pulling on the drag link of course to keep the tires straight and its twisting back and forth real hard. I may try to mount my GoPro up so I can watch what it is doing when its shimmying. So what I am going to try to do is first (since it didn't shimmy on the way to get the alignment at all) is then I can mess with a bit more toe in and see where that takes us. Lol, will take as while though everything is so big and heavy and tall its hard to get weight off the axle to change some of these things. Last thing I could also try is taking the camber adjusters out and put back in the dead straight upper ball joint screws. When those are in tires are a bit cambered out but if it stops the shake then so be it.
Will let you know what happens.
