"TURDLE" or " How to mess up a perfectly good truck" | Page 7 | Ford Explorer Forums - Serious Explorations
Status
Not open for further replies.
Well, it is about time I do this
This is our 1998 Mountaineer.
We acquired it in late 2000, with 29 k on the odometer. Previously it prowled the Oklahoma turnpike as an unmarked police cruiser.
I would say it was about June-2001, when the initial madness set in, and I became obsessed with changing the looks.
I found Explorer Express, Where I scored the x-spec suspension.
After talking with John V., I learned of the Apten group buy here, and the rest is as they say, history.
In June of 2002, I acquired an exhaust leak. Being the expert I thought I was, I bought a header gasket set, went to fix it.
Well, in my thinking I didn't have the front bolt tight enough, I snapped it off into the head---ooops.
After pouting about this for awhile, I decided to really get into this site for answers.
The result--
347 cubic inch, stroked and bored engine
FMS sportsman block-bored .030 over and machined for stroke
Billet crankshaft with chev rod journals
H-beam ultra light rods
Probe PRS forged pistons -9cc dish ( slightly over 10:1 compression)
Melling stock volume oil pump
Edelbrock performer efi heads 2.02 intake, 1.60 ex valve 58cc chambers
Crane's roller lifters--billet aluminum lifter guides
Crane's roller rockers
comp cams pushrods
Cloyes true billet double timing set.
FMS X-303 camshaft, advanced 4 degrees
Professional products Typhoon intake and EGR elbow, with 1" phenolic spacer
FMS 42 lb injectors
Aeromotive fuel rails, boost reference regulator ( currently set to 43 psi.)
Walbro 255LPH fuel pump--return style 3402
Lightning MAF
Torquemonster headers--stock exhaust with rear cats removed--magnaflow dula in single out-Hooker Aerochamber stacked right behind, 3" mandrel bent MAC tailpipe.
Art Carr 3000 RPM flash lockup converter ( 10 " billet housing)
Art Carr built valvebody kit
Amsoil fluids in all otherwise stock components. ( since I change my oil early and often, I use the least expensive synthetic oil. Usually Amsoil, but sometimes I will use Mobil 1)
AWD IS OUT!! 4406 4X4 IS IN!
http://www.explorerforum.com/forums/showthread.php?t=166726
http://www.explorerforum.com/forums/showthread.php?t=185203&highlight=turdle
UPDATE
As of 2-17-08
I mentioned the truck being a poilice cruiser in it's first life-
well, this caused a little "glitch"
While the PCM says it is a NRT1 box code, somewhere along the line a police code was flashed into the PCM.
My original paperwork shows a dealer service call for a PCM reflash right before the title was signed over. I am assuming the police tune was recovered, and a stock tune re loaded.
However,
they didn't mention they loaded it with a MC2O box code.
After 2 trials with the initial run tune, I actually read the box code with the XCAL2 and James deteremined This error.
Once this was figured out-the tuning was ON!!!
Baseline tuning is complete and all is well. I'm waiting on a new Innovate LM-1 wideband for WOT tuning.
Somehow mine took a dump,
I spent a whole day trying to figure it out. If it had been operating though it would have been a breeze.
James ( jah81592) is about the best help a guy could ask for in this area.
www.hensonperformance.com
UPDATE 2
Tuning complete-after a few WOT pulls to 6000 rpm's
James has not only achieved a great tune in my truck, but totally eliminated the surging issues I was experiencing.
UPDATE 3
Truck now lifted for trip to Colorado Gold mine trails--page8
Update 4
colorado trip completed-Imogene pass and Black bear pass have been driven in this truck
woo hoo!!
picture of black bear pass-
update 5
On Sept 19, 2008 Went to KCIR and ran a 14.8 @ 90mph---2.002 60 ft time
I was snoozing and did everything wrong. It has more in it.
Update 6
After drooling over Mountaineergreen's extensive suspension mod list for years-
With a feeling of guilt, for not doing the actual work myself, I have acquired his
4" superlift suspension lift,
410 gears
aussie locker in rear
disconnect front diff--- http://www.explorerforum.com/forums/showthread.php?t=188359
double cardan front drive shaft ---http://www.explorerforum.com/forums/showthread.php?t=185232
285-75-16" cooper discovery sst (33") tires
UPDATE 7
Exhaust Dumps installed 4-15-2009
These allow the exhaust to be opened right after the cats.
new pics as of 3-16 2009
attachment.php
attachment.php
update 8
Added another stock trans cooler beside original, installed hard lines and twin 10" cooling fans
They seemed to work just fine
Update 9
Sliders installed!!!
http://www.explorerforum.com/forums/showthread.php?t=245321&highlight=sliders
I used Smoked chrome powder coat on front and rear bumpers, sliders, and wheels make for a factory look match
Bumper pictures are before slider install-
attachment.php
Next up--Get rid of torsion bar drop brackets, and, the bars themselves.
I also have some mild white neon tube rock lights, some very bright 55w rock lights, and, 6 rock llight of death tubes ( to be shown later)
stay tuned!!
Oooo! I just got all kinds of excited!! That looks awesome, CDW! I may take that route as well, instead of tearing the block down ;)
^^^Looks sweet! :thumbsup:
mmmmmmm.....nice
I like it, but I also don't want to advertise. I would like to find a 347 plaque for the stock intake, I haven't seen those in years.
Showoff:p:
Emblem is sweet!
Is that a BIG S ???
Yes-
It came off the family farm in Nebraska.
Somehow it's going on my garage, right between the second story window and the garage doors. My garage has a second floor up there-
good eye:thumbsup:
Yes-
good eye:thumbsup:
It almost looked like you had a big S painted truck or maybe a black and white 22. buts its just a reflection :p:
Ok i thought it would be something like that.
Nice emblems too
Jon, we spoke about the wide gap between 2nd and 3rd gears of the 4R70W.
The ratio difference between the 4R70W and AOD's(AODE also) is about the same as that of a 3.73 to 4.30 ratios. You can swap to a planetary from an AODE, and change to 4.30 gears, and end up with the same 1st and 2nd gear final ratios. The truck would gain a lot in 3rd gear, being at a 4.30:1 instead of 3.73:1 final drive. The high gear and fuel economy would drop a little, as it should with ring/pinion gear changes.
The sunset last evening was spectacular-
so I grabbed a pic-
nice pic of ur mounty jon
Lookin' sharp, man. :)
hey Jon, what kind of pillar gauges do you have (Type and brand)?
The Mounty is looking awesome as usual
I have Autometer sport comp gauges
in the pillar are volts, boost-vacuum, and Aif fuel ratio ( which is a waste of time)
I have a dash pod with 2 cylinder head temperature gauges.
Hey Jon why do you consider that AFR gauge a waste of time?
Status
