postquantum
- August 7, 2014
- 2000 ford explorer xls
Hi guys!
This is my second explorer build, and first of this generation. Im doing the balance shaft chain tensioner on my 2002 4.0 explorer and Im in the rebuild phase (for the second time now). My brilliant self decided to torque the upper oil pan (I think Its called block cradle) reinforcement bolts (13mm) to 87ft-lbs, the torque setting is (should be) 10 ft lbs. i put two small cracks on inner middle sections of the upper oil pan, but they are inner sections next to the bolts, right on corners (inside, not on the sides of the pan) of where the metal corners to make a hole, and they are both all the way through.
Will this be safe to finish putting back together? All the outer bolts are fine, its an inner reinforcement of which there are many, and the rest of everything sits perfectly.
Thanks!
Thanks!
