BrandonB8
- September 27, 2002
- St. Louis
- 1995 XLT
Ok I read the post on how to do the torsion bar adjuster removal. I rented the autozone two gear puller and put it in the dimple. It didn't sit flush but after screwing it up into the dimple it held securely. I tightened it up and removed the adjuster bolt(screw) and began to lower it down. the gear puller slipped and is now wedged sideways preventing the adjuster from dropping all the way down. It did make a loud pop so is all the tension released. I am afraid to free it up by banging it with a hammer because I really don't feel like getting hit with a puller missle. could I put a jack on the torsion bar itself and raise it up enough to release the tension holding the puller up there? Please help me I have to go to work tomorrow and need to get this fixed. If you don't understand the way the puller is currently at, instead of being in the hole, it slipped and is now parallel to the ground instead of perpendicular. the Clamps are still attached to the adjuster brackets. PLEASE HELP ME
