Oversquare
- June 14, 2004
- Wine Country
- '00 XLT 5.0 AWD
I have a 2000 XLT V8 (5.0) with 70,000 miles. In the cold mornings when I start it, sometimes the oil pressure "idiot gauge" reads 0, and the "check gauge" like is on. If i turn off the engine, and then restart it, the engine will restart normally and the gauge will show normal pressure.
Under hard braking, steep descents, and hard cornering the gauge doesn't move. When the engine has been run earlier in the day, it doesn't do it.
I have a feeling it is the sensor or the connector to the sensor. I doubt it is the actual oil pressure or oil pump.
Where is the sensor located on the engine block?
Has anyone had the problem before?
-Brad
-Brad
