- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
While I have 93 ranger it does share a lot of parts with the explorer. I have a nagging overheating issue on long grades I want to get rid of. When I am going to the local trails I climb from 1600 feet to 5000 ft in about 12 miles. It is one long continues pull. I pretty much put it in 4th and hold my foot to the floor to the top to hold 50 mph. It will hold the speed but the temp gauge starts to climb. As soon as I clear the grade and get into the tight turns the temp comes right back down. It will get slightly warm around town when the outside temps are 90 plus If I drive it fairly hard.
I know part of my problem is my winch is blocking airflow to the radiator. Short of getting rid of my winch that wont change, so I need to deal with areas I can change. There are a few areas I feel that can be improved: Radiator, Fan, Fan Clutch.
I am currently running the factory single core radiator. My understanding is there is a duel core radiator that is out there that can bolt in. Is that correct? When I change from single core to duel core I need to change the shroud as well correct?
Listed on Rock Auto is a 9 blade fan ( I currently have) and a 10 blade heavy duty fan.Has anyone made this swap and noticed a difference? Anyone know the CFM difference between them?
There is a standard duty and heavy duty fan clutch listed on Rock Auto. Has anyone ran either of these and been able to notice the difference? What is the difference?
My truck never runs warm on the trail. It can be 100 degrees plus outside and I can leave it idling or pulling in double low with the temp staying nice and low.
Any opinions?
Any opinions?
