Yes the early trucks had the aluminum bodied dpfe
Differential pressure feedback exhaust
Just fyi
The aluminum ones plug up internally with corrosion and crud
I always replace the metal ones with the 98-01 plastic style
Your check engine light bulb is likely just out
The cluster is not that hard to get to
You just need a Phillips, a 7mm and a 8mm socket
Can have the cluster out in less then 15 minutes once you do it a time or three hundred
If you installed the new thermostat with the weep hole pointed up then I really doubt it is stuck, the 4.0 has a hard time burping all the air from behind the thermostat sometimes. The temp will read higher because the sensor is actually in a pocket of trapped air. There are several clever methods members have come up with to remove the air bubble over the years… I have found a couple I like. When it’s at temp just start squeezing the upper hose, this helps the system move coolant and release the air.
Make sure the overflow tube is not plugged.
Some people park on a steep incline with the engine raised, I have also been known to pour hot water down the upper rad hose directly to the backside of the thermostat forcing it open and thus releasing the air
