What is your opinion?
Kfred
Fairfield, PA
1997 Eddie Bauer
I am getting new subs becuase i am moving on to bigger and louder subs than my 2 10" kicker cvr's i have now.
I first decided that i wanted a ported box for starters. I now am trying to decide what sub to choose from:
They will be powered from my planet audio amp which can handle 900 watts rms @ 1 ohm.
2 MA Audio MA150XE 15" 900 Watt subs :
900 Watts Power Handling per Subwoofer
450 Watts RMS Power Handling per Subwoofer
Dual 4-ohm Copper Clad Aluminum Voice Coil
150 oz. Double Stacked Strontium Magnet Structure
High Profile Triple Treated Rubber Surround
Platinum Plated Block Terminals
Hi-Temp Kapton Voice Coil Former
Dual Progressive Dupont Spider
Ultra Strong Polypropylene Dust Cap
Patented Thermo-Cooling Motor Structure
Sensitivity: 91.62 dB
Impedance: 4 Ohm Single Voice Coil
Mounting Depth: 6.5"
Mounting Diameter: 15.0"
Optimum Vented Box: 4.0 Cu/Ft
Optimum Sealed Box: 1.5 - 1.75 Cu/Ft
$138 for a set
or....
KICKER 2010 C15 15" SUB :
Kicker C15 15" Subwoofer Single 4 Ohm 250 Watts (10C15-4)
Power Handling:
Peak Power: 500 Watts
RMS Power: 250 Watts
Impedance: Single 4 Ohm
Sensitivity: 90.3
Frequency Response: 25-500 Hz
Mounting Depth: 7-7/16"
Mounting Cutout: 13-11/16"
Recommend Sealed Box Volume: 2.25 - 5.00 Cubic Feet
Recommend Vented Box Volume: 3.00 - 4.00 Cubic Feet
$164 for a set
the box:
Port Tuned @ 38Hz
Gold-Plated Speaker Terminals
Show Quality Custom Carpet
Dimensions (W x H x D): 38.25" x 16.25" x 16.5"
2.75 cubic ft per sub
What do you guys think??
NRA4ever
Minden La
2003 Ranger Edge
Kicker if you want them to last. I use Elemental Design subs. They hit hard & low.
Kfred
Fairfield, PA
1997 Eddie Bauer
i well i had my old set of kickers for like maybe 7 months and i was powering them by a 1200 watt Planet Audio monoblock amp, it was turned down since i had 2 and they together handled 800 w rms as a pair and i didnt want to overpower them. but one of them had a weird hum to it when it played, i never could figure it out.
but i actually opted for a set of Power Acoustik P2-15w, they are 15" subwoofers and they are rated around 1200 w rms which i would prob say may be overrated a little bit. I have never owned anything power acoustik so i will see how they handle everything.
