jd4242
- October 15, 2008
- Points
- 113
- va beach
- 92explorer&94 ranger
it was a 5spd 2wd. my truck has 3.55s and ill have 31x10.50 15s on it by the end of the week. i do understand what youre getting at though. weight and drivetrain drag changes it all. ive read that the nice thing about the v6 is that it makes a ton of torque over a broad power band which makes it very versitle. i do plan on regearing the truck in the future and off roading it a bit. would be nice to only modify the truck where needed
If it was me I would build a nice 422 ohv and throw 4.56 gears in it, IF AND IF you dont do ALOT of long or high speed highway traveling. .that combo you would be very happy with and be the cheapest easiest route. .bare minimum run 4.10 gears if alot of high speed long highway use..personally I would gear first (choose gears based off that info^^^) then decide what motor you want..gears will make your truck a WHOLE new truck, promise you that..also gears are not cheap at all and there is WAYYY more to a v8 swap then you think, even if it is carb..
Fyi my sc motor and truck I ran 4.88s and had a set of 33s street tires and it would flex the whole suspension out, almost picking the front end off the ground and put a smile on your face every time
