inh
- June 30, 2005
- Springfield(ish), MO
- '00 XLS
Granted it may be a bit pricey, and you'll probably have to fab up adaptors to bolt to the block and give you a threaded fitting for a hose, but even given my limited machining experience, it wouldnt be too hard. A bit pricey, but not as bad as other pumps out there, plus you can order replacement motors for this should it ever die: http://store.summitracing.com/egnsearch.asp?N=115+400179+307491&autoview=sku
