Wrong hole | Ford Explorer - Ford Ranger Forums - Serious Explorations
Wrong hole
right so i just a phone call from my aunt that she poured powersteering fluid into her transmission. so now tommorrow i have to go and flush it out. WTF. and its goin to be way hot out. were going up to `110 and the average is 95.
ill post updates later on.
alexk
New Jersey
2021 Limited
Wrong hole..thats what she said!
YBCold
Las Vegas NV
91 ×∟┬
hahah u watch that show?
YBCold
Las Vegas NV
91 ×∟┬
im going to do it tonight already too hot for me outside. ill just rock the maglight tonight and do the fluid change
short1
Kenosha, Wi
2006 Limited
good luck, can the ps fluid do any damage to the transmission? mess up the seals or anything like that?
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Umm, power steering fluid is pretty much the same as ATF.
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
depends on what kind of p\s fluid. vw audi use a green mineral dased fluid.ford does use atf .so what kind did she use?
I hope that she can tell the difference, other than that you are screwed. You will have to completely flush the tranny. Try about $100-$200 for a good flush.
YBCold
Las Vegas NV
91 ×∟┬
dammit. well she didnt put a whole lot but i dunno what happens when u do that anyways. so ill just drain it and refill it anyways. as it is now her car is consuming transmission fluid anyways. sun should go down in about two or three hours then ill go out and do it
