nostopin
- November 21, 2010
- nor cal
- 93 exporer
(this is over a period of about 6-8 months) To keep a long story short, my 93exp started running like crap and went from 20+ mpg to 14. just changed the plugs and wires 2 months prior. I thought it was a plugged cat so I cut the bottoms out of them and took the stuff out, then welded the bottoms back on (cant get the cats unbolted from the Y pipe) Ran good, but still bad Mpg. Checked for vac leaks and found none (sprayed ether while running and got no hits on the vac lines) took it to a shop and hooked up the OBD1. dude said it was something wrong with the EGR valve, cant pin point it, but something with that system is bad. So I replaced the EGR valve and got no improvement. just last week I changed the plugs, wires, and O2 sensors. (plugs had white burnt crap built up on them) The replacement O2 sensors were cheap ones from Rockauto, they looked a lil bit different and had a black plug instead of white like the harness and the plugs on the old O2s. it ran like hot garbage for about 30 min after I changed them, but then cleared up. still only getting 14mpg.
OH and the exhaust has smelled BAD when i decelerate or come down a long grade this whole time. Do the plug colors matter on these O2 sensors? Got some electrical contact cleaner and will clean the MAF and all the plug connections I can with 1 spray can and report back any findings
