- February 18, 2015
- Phoenix Az
- 1991 aerostar
I've been reading your other thread, not sure how much help I can be. Don't assume the replaced parts are good, new means untested. If the check engine light illuminates while cranking the engine, the crankshaft sensor is good. For the camshaft sensor, check the supply voltage at the connector. One lead of the volt meter on the connector and the other to ground. You should get battery voltage. If you trip the inertia switch, or kill the power to the fuel pump so the engine won't start, plug the ckp in and probe the wires on DC voltage, each time the sensor passes #1tdc you should see a read of about 5V. If these check out, I don't have a wiring diagram. If someone posts one I can help with chasing wires to test.I have no experience with a volt meter or anything related to it. So I'm wondering if anyone out there could help me out. Trying to trouble shoot my 214 code. I have a Haynes manual but it's pretty vauge. To test the ckp it says to disconnect, turn key on and test for voltage of 1.5. I did this by touching my positive probe to the connector and the ground probe to the frame. Then it say to check connector while turning the engine over and turning your voltmeter to ac and check for pulsing voltage as you crank the engine
How do you do this if the connector is hooked up? Do I back probe the positive into either wire and the negative to the frame? When I tried that nothing happened. I dont know if I am doing this correctly.
When I tested the crank sync it had battery voltage but when I turned the engine over backprobed into the signal slot and negative on the ground in the engine bay the voltage jumped all over but was never 5 like the manual states....please help!!
