- December 16, 2010
- Greer, SC
- 2001 SAS'd Sport Trac
Gotcha on the sway bar
So for highway driving higher 30s you think is good pressure?
Just a side thought, you took out your front sway bar right?
Here is my post in my thread about the hitch flip. In case you feel like ever doing it.
http://www.explorerforum.com/forums/...&postcount=123
Are you still running 4.10 gears? Iv been warned by a couple people that dogging it down on the highway can burn up the overdrive.
I'm also looking at a couple different tuners to fix the speedo, odometer and ABS.
Me neither. ABS is the only reason I'm considering doing anything to the speedo. Then again it passed inspection yesterday. I noticed it on steep wet trails the wheels lock up so I have to pump the brakes instead. Not too big of a problem but it kinda worries me on the road if I'm forced to do an emergency stop.
Probably should update with this as well since I just realized this a couple days ago and snapped a picture:
Gonna have to look into this.
hey runner have you checked the fuse? i remember when i first went to 33"s, my abs fuse blew for some reason. i have no idea if it was related to going to bigger tires, but i remember it happening, and after i changed it, i havent had a problem with my abs since.
