94 Dual Sport | Ford Explorer Forums - Serious Explorations
94 Dual Sport
Micah J
AZ
94 Expo
94 Expo
Copy Cat D44 conversion brackets
Dana 44 TTB completely plated uniball pivots
High clearance radius arms attached to the back of the beams, heim pivots
F150 leafs
Disk 8.8 with 5x5.5 conversion adapters
12" 3.0 IBP Fox coilovers in the front
12" 3.0 Raptor IBP rears
Rear axle mocked up, to be swapped for a 9"
Radius arms tacked up
Pivot brackets finished welded
another sick gen I!!!!!!!!!! very nice
She should be bad! Front fenders need a lot of trim. Don't plan on running glass. Frame needs to be notched for the diff. Tire hits fender as beam hits frame
Rear is an f150 8.8 and full 91 f150 leaf packs minus overload.
Sweet! Just bought all the parts to do this to my 91. Can’t make my mind up to go coilover or coil and bypass.. leaning toward the latter.
These look so good with 1/2 ton axles under em 💪🤙🏻
Hell ya its a blast, much more fun than my last d60 leaf sprung lead slead.
I would go IBP if you still need to buy shocks. Trying to stuff 4 shocks under the hood gets really tight.
That turned out slick!
Tons of dirt miles since last pictures. Thing takes a beating and just keeps on moving. Fast in the open desert and goes a lot of places it shouldn't in the rocks.
Cage and rear links are next on the to do.
