Re-Assembly Complete
The forward clutch required quite a bit more air pressure to move the clutch pack than the manual suggests. The manual states that no more than 20 psi should be applied when air testing any of the clutch packs, however this one required something in the neighborhood of of 60 psi to move.
I believe part of the reason for this is pressure leakage between the drum and the center support (though it was impossible for me to verify). Here is the setup for air testing this drum:
Initially, I did not apply higher pressure. Thinking something was obstructing air flow, or possibly a bad seal, I disassembled the drum completely, then checked for air flow at the air inlet of the drum here:
I thoroughly cleaned and blew air through the ports in both directions. There was air flow through the port, though it seemed a bit weaker than it should have. I could not detect any damage to the center support or interior of the drum that would cause pressure loss.
Does this indicate a problem? Hopefully this is normal with this drum. At any rate, I reassembled the drum and found that the clutch would move with higher pressure applied. I'm not sure why the manual recommends such low pressure when the trans experiences much higher pressure in operation. My guess is safety concerns.
Everything else went smoothly.
Here we have the drum assembled, checking the clearance with feeler gauges (.055 - .083 inches), I had to stack two to get the thickness required:
Next is the forward geartrain assembly, here are the pieces:
First we place the forward clutch into the intermediate drum (which air tested fine with low pressure) with the bearing b/w:
Next we insert the forward ring gear with the washer b/w:
Followed by the bearing then the forward planetary:
Followed by the forward sun gear/input shell:
That assembly is together. Next we turn to the overdrive assembly. Here are the parts:
First we insert the OD planetary into the center shaft/sprag with the bearing b/w:
This planetary is a replacement part from a W/N/S (not E) model, but the fitment seemed just fine in all aspects. Here we check that the sprag is doing its job allowing counterclockwise rotation but not the other way. Next we insert the front sun gear into the OD planetary:
Sidebar: the manual refers to the OD drum (and related parts) as the "front" drum - these terms are interchangeable in my mind. But front is too similar to forward, which is actually the drum in the rear of the case. The nomenclature could be better, but labeling and pictures help immensely in keeping it all straight.
I seem to have missed a photo of the "star" coast clutch adapter, but it pops right on the sun gear. No clearance issues with the plastic damn in the revised OD planetary.
Next we insert the forward geartrain assembly into the case along with the intermediate band and apply/anchor struts:
Followed by the
#4 bearing then the center support (here you can use the input shaft to align the geartrain and the center support):
Next we insert the retaining bolt/cage through the bottom of the case as well as insert the TSS sensor and route the wire to the connector:
Next we insert the
#3 bearing then the OD assembly into the case (there's the star adapter):
Followed by the OD/coast clutch drum then the OD band and apply/anchor struts:
I did not disassemble the pump, so next goes the input shaft, then bellhousing/pump assembly including the
#1 washer:
Bolts torqued to 35 ft lbs.
Here's a money shot of the case as it stands proud on the stand
Next we insert the servos, covers and snap rings (don't mix them up). The tool was not necessarry, just apply some pressure with your palm and they stick right in:
Next we torque the intermediate band to 10 ft lbs then back off 2 turns, followed by the OD band to 10 ft lbs then back off 2 1/2 turns. I had to be a little approximate here as the end of the adjuster bolts are square, which doesn't play well sockets, my only means of employing a torque wrench. So I used an 8mm wrench then stuck a torx bit in the other end of the wrench which connected to to torque wrench - this of course lengthens the lever and increases torque a bit, hence the approximation.
Tighten the locknuts do 40 ft lbs while holding the adjuster bolt in position. This had to be approximate as well as holding the adjuster bolt in place blocks the use of a socket - same problem:
If I had followed the order of the manual, my trans range sensor would still be off at this point, but I didn't, so clearance is tight in the intermediate adjuster bolt:
If you loosen the two mounting bolts of the range sensor you can get enough play to thread on the locknut and adjust the bolt, just barely.
It's time for the trans to come off the engine stand:
Stand plate off:
Next we insert the solenoid cable harness (I know my wires are in bad shape, but they are pricey to replace):
Next we install the valve body and gasket (you used a bolt template at removal didn't you?
Note the manual valve is slotted into the shift linkage pin. Torque the valve body bolts to 90 inch lbs in the proper sequence. Next goes the detent spring, reverse servo gasket and cover (careful, the gasket is easy to flip around and misalign), pan gasket, and filter:
Next goes the pan - torque bolts to 125 inch lbs sequencing across the pan:
Almost there! Next we install the OD sensor and the output shaft sensor (top of case), as well as the vent pipe:
On the other side we install the heat shield:
All Done!!! Oh ya you still have to install it... and slap in the torque converter when you're ready
Here's a shot of my empty parts table and all the damn labels (this was a great idea):
And the parts table for those wanting to do something similar:
This was a long job, but it feels good to be done. Also, it gives me the confidence to tackle any other transmission issues i may have in the future on this vehicle or others. Time for a beer or four.
