- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I asked if the rear driveshaft has a cardan joint, many people call it a cv or constant velocity joint. You said after they replaced the u joints it had vibrations
No vibe before work and big vibe after = check their work. If they replaced both u joints in the cv part of the rear d shaft there is also a small bearing, soring and seal inside the cardan joint. They can be tricky to replace and if screwed up this could cause a vibration as you deacribe
It’s not a bad idea to make a new thread forum joint issues but at the same time I don’t care if we discuss it here in my sport trac thread because you know I will respond here and this is a discussion forum. However it is nice when some threads stay on topic… so I will leave that up to you.
Moderator and my friends are just trying to help!! No feelings needed
I just talk about trucks same as I would if we were all sitting around a campfire, you never know where the topic will lead
