2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Engine to trans alignment
It is important to align the crankshaft axis with the transmission axis by adjusting the lift chains to avoid damaging the transmission seal when removing and installing an engine.
You may want to look thru the following thread starting with page 20:
SOHC V6 Timing Chain Saga
Make sure the torque converter does not slide off the transmission input shaft when removing the engine.
Using the replacement engine installed flexplate will save some time.
The crankshaft position doesn't matter for an assembled engine.
