1991 XLT SAS Tech Input Needed
pantherXLT
Hudson,North Carolina
'91 XLT
I own a 1991 Xlt 4x4 automatic 4ALD tranny 4dr with manual locking hubs and manual transfer-case! I would like to here from you guys that have already done a SAS on your ride! What is the the best axles to use !!!Leafs or coils is my next question ,or should i just lift the TTB .I like soild axles and if your going to spend $1200 to $1500 on a ttb lift I would think a SAS is the way to go!! So HELP ME DECIDE PLEASE:exp:
pantherXLT
'91 XLT
Thanks for the input :exp:
pantherXLT
'91 XLT
What lift should i use if i decide to go that route and a link would be great or brand and size of lift:exp:
pantherXLT
'91 XLT
Best Choice of SAS on a 91 XLT 4dr
Hello guy's I need some SAS ideas I'm thinking of doing a SAS on my 91 4x4 xlt 4.0 automatic tranny, manual locking hubs and manual transfer case .What is the best setup >>>>Front Axle>>>>Rear Axle>>>Leaf Springs >>>or Coils and all parts do i need to get:exp:
Four0Sport
Jack Pewe
West Virginia
1993 2dr
for a TTB D35 lift.. alot of poeple are using the Rough Country 4" lift. make sure you also buy a drop pitman arm from them, itll help reduce bumpsteer and correct some of the steering.
are you planning on doing a spring over axle conversion for the rear? or do you want lift springs for the rear? take a look at www.RoughCountry.com, look at the lift for a 91-97 ford ranger, there is a scroll box for the Explorer kit. the full kit is a little pricey, but worth it!
i purchased the drop pitman arm $60, 4" front springs $125, and 4" drop brackets for the axle pivots $225 and 4" ext shocks $120. for the back i already had warrior shackles and AAL.. front is a solid 4" and the rear using AAL and shackles is 3". im in the hunt for lift leaf packs as we speak.
whatever you choose.. keep us posted, and good luck
you can check the link in my signature for some info on the setup and other things i have done to my explorer.
pantherXLT
'91 XLT
Ok I will and thanks :exp:
pantherXLT
'91 XLT
Okay so I guess this will work a 4"inch Rough Country ttb lift with SOA in the rear and 2"inch f150 coil seats in the front will give me 6 inches of lift.and to top it off get a 3 inch body lift.So what do you think will that work!!:exp:
Four0Sport
Jack Pewe
West Virginia
1993 2dr
that sounds great.. but do you really need the body lift with 6" of suspension lift?
dont forget about the alignment after the suspension lift, you will need adjustable camber bushings.. might want to put those in yourself b4 you take it to get it aligned, most shops charge alot to install them.
i went with just the 4" kit and it leveled out the front and i didnt need the camber bushings.. but if you go for more lift than the drop brackets are made for you will need them.
pantherXLT
'91 XLT
Here is the X
Stock:exp:
pantherXLT
'91 XLT
Been in the family since 91 need some TLC and lifted never been off-road I bought it from my stepson and he bought it from his uncle I have own Toyota's 4x4's and 4wheeling them for about 12 years so 4wheeling is my thing!Never owned a explorer til now I've had it about 1 year:exp:
glfredrick
Louisville, Kentucky
86-98 Ranger STX
I would advise against 9 inches of lift! That is for street queens only, unless you plan on running 38s, and the axles won't handle that!
I like BDS lift kits -- the brakets are better than Rough Country, and everything is lifetime.
What size tires are you trying to run? Makes a difference.
pantherXLT
'91 XLT
ok thanks ,I not going with body lift 33 or 35 and on the SOA what axle perches should i use
pantherXLT
'91 XLT
and also does the lift kits on a ranger fit a explorer
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
The best choice is really a matter of opinion, there are many ways you can go about it. Your in the right area so have a look around and see what suits your needs best;)
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Threads merged -- pantherXLT please keep all your SAS ideas in this thread.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Okay, 33-35" tires, what are you going to use the truck for? Mudding? Hunting/camping? Pavement pounder? Rock crawling? If its going to be a trail rig i would go ahead and do an SAS... everything else i would just lift it and re-gear.
9 1991 XLT D44/Ford 9 swap Offroad Projects 14
Sævar Örn 46" 1991 Explorer in Iceland. Offroad Projects 141
glom742 1991 v8 swap and other stuff Offroad Projects 10
Kirby N. Kirby's 1991 Ranger Build Up Offroad Projects 523
rednecksoldier rednecksoldiers 1991 ex sas and soa Offroad Projects 20
MountaineerGreen MountaineerGreen's 1991 D44 SAS Offroad Projects 25
F 1991 ranger SAS 44/9 first test Offroad Projects 10
Burns 400 M into a 1991 Explorer Feeler Thread! Offroad Projects 39
G V8 into 1991 explorer Offroad Projects 39
M Swapping a 95-96 4.0 v6 into a 1991 Explorer Offroad Projects 1
JungleSkunk Project Pale Rider 2.0 98 XLT Budget trail rig Offroad Projects 60
Explorin'VA 94 xlt project Offroad Projects 106
J Project Opinion Wanted: '93 XLT vs. '99 Sport Offroad Projects 1
dbush72 dbush72's "I'm gonna SAS my '02 XLT" Offroad Projects 5
N 98-XLT's "92 Explorer SAS" Offroad Projects 6
S 96 explorer 2wd xlt limited pre runner project Offroad Projects 1
9402xlt 94 xlt sas Offroad Projects 12
DUDER 1 93 XLT Dana 44 front axle swap. (I NEED HELP PLEASE). Offroad Projects 39
410Fortune 410Fortune - 96 5.0L XLT refurbish (making 1 great Ex from 2) Offroad Projects 613
C 2001 XLT D44-SAS Offroad Projects 437
S 94 xlt snorkel in the making Offroad Projects 8
C CHIEF Is Almost a 302!!!!!! 91 XLT SAS In the process of 302 and T-5 Swap!! Offroad Projects 545
E Preparing for Engine R&I '93 XLT 4.0 Offroad Projects 2
M Seat Swap: '00 XLT Power seats into '02 XLS????? Offroad Projects 2
gfennie77 '91 XLT -> 5.0L, C4, Dana 20, 4" Lift Offroad Projects 11
B 4.6 SOHC V8 in 2000 XLT Offroad Projects 7
Mbrooks420 Sohc in 1996 Xlt Offroad Projects 6
aldive Painting the Grill on a ’99 XLT - aldive Offroad Projects 25
Kris Guilbeaux Kris Guilbeaux' 1992 Explorer XLT project is Home Offroad Projects 145
F Putting a V8 in a 94 XLT Offroad Projects 1
G 2002 XLT Issues/problems anyone? Offroad Projects 2
E 4.0 -> 5.0 Conversion on 96 XLT Offroad Projects 1
Gofast 302 Conversion, Part II 94 XLT Offroad Projects 109
S let's see your steering box on gen 2 sas Offroad Projects 4
ovrlndr Jay's '92 SAS on F150's Offroad Projects 1
KurtECV The Black Pearl SAS and build Offroad Projects 362
G 2001 ex SAS project Offroad Projects 4
C Chato's '98 V8 Mountaineer SAS build Offroad Projects 4
9 2000 5.0 sas question Offroad Projects 3
F Dana 44 purchased, SAS questions! Offroad Projects 7
L SAS on tons and 40" Offroad Projects 2
SVO42 mushy brakes after SAS Offroad Projects 6
A 2005 sport trac Dana 30 sas (Version 2.0) Offroad Projects 24
madbutcher Madbutchers shitmachine sas Offroad Projects 93
1 D30 sas/soa Offroad Projects 4
F FullBlownModz Dana 44 SAS Build Offroad Projects 18
D Project "Twisted Sister" SAS Front Dana 44, Rear Ford 9" Offroad Projects 46
A Explorer SAS or not for daily driver? Offroad Projects 1
boominXplorer Superduty D50 axle for SAS? Give me your thoughts........ Offroad Projects 7
JTX JTX's Return! 1997 Mountaineer Build Thread SAS/4wd Conversion Offroad Projects 65
Similar threads
