In the models(99-01) with the better stereos, the long console has audio controls on the rear of it. Those are the only ones that could have the speaker wires go into the console connector, and they also come out of it(in series so if you disconnect the console, the speakers don't get the signal). That might have also been a 98 model year change, my 98's don't have that problem. I never thought of how those could be OEM wired differently.I have no console and I did not loop
Anything? Speakers work… first I’ve heard of this!!
NSS is now just a loop of wire at the trans harness connector. The starting wire (under dash) is split through the CPP pins 5 and 6, a normally open switch. That's how the starter is disabled until clutch pedal is depressed.@97Sandbox So Grant, in the wiring diagram in post #879, there are 3 switches in the switch for the clutch pedal, that would be the 6 pins on the switch and the start/neutral safety switch is open until you press the clutch pedal? Is the switch within the switch to disengage cruise closed to send a signal to the cruise to module to disengage cruise control?
Are you saying you never ran into the sub/HU compatibility issue in '98+ rigs?My old 96 when I wired up the stereo I had to bypass all the factory wires pretty much… I installed a 5 channel amp and small sub. I was able to use all the factory speaker wires running into the doors but I had to get access to them by removing the entire cargo area panel and factory amp and sub amp. So it makes sense that they changed things in 98. Never had to do that on the “newer” rigs
5V? Wiring diagram says 6V haha. I haven't touched the wiring to the sub amp, but I'm no longer getting signal to the sub since I put in the base head unit to replace the dead Mach HU. Is there any quick fix to get the sub back up and running? I thought there were non-Mach systems that still had a factory sub.Oh yes! To power the factory sub it needs 5v power supply not 12 and you need a bass
Blocker in the rca line signal to it
I am using the factory sub in the 03 with a atoto head unit and aftermarket door speakers. I learned about the 5v power supply and bass blocker on this forum and made it so
Atoto f7 we $165 on amazon w rear camera
With mounting brackets installed
Brackets modded to clear switches
Perfect fit
Glued the mic in place to cover the hole in column shroud, worked perfectly
Mounted
The wiring is a little tricky, good to have the 03 sport trac wiring book (I have 01, 02, 03 and 05 books for traxs now)
Basically to get the factory sub to work there are 3 wires power to sub amp (remote turn on) which is a 5v feed or you will get a “thump” each time you turn the key on. So we use a 12v to 5v resistor inline. Also the atoto subwoofer rca out is full range so I used a low pass inline filter to block out all mid and high ranges, keep bass to 100hz. Have to cut an rca cable apart to get the + and - feeds. All in all it worked out easily without having to buy an install kit or wiring harness (I never do)
This is the 12v to 5v step down used for the remote wire to factory subwoofer amp
RED WOLF Car 12 Volt to 5 Volt Step Down Adapter Harness Fit Aftermarket Radio Stereo Install for Early Ford Mustang Lincoln https://a.co/d/hqj1r1P
Here is the inline bass
Filter
FMOD Crossover Pair 100 Hz Low Pass https://a.co/d/dzilhN0
