Hello everybody, I need help bad, my 2002 Explorer had not overdrive the OD light was flashing always, and changing from 1 to 2 gear the RPM was very high, so I decided to go on line and buy a selenoid pack to install it on the car, when I removed the transmission pan I found on the bottom of it a piece of the overdrive brake band and the anchor that holds it, looks like the piece broke..NOW THE BIG QUESTION: CAN I BUY A NEW BAND AND INSTALL IT WITHOUT REMOVING THE TRANSMISSION FROM THE TRUCK..
PLEASE HELP!!!!!!!! I WILL POST THE PICTURES OF THESE 2 PIECES..
THANK YOU
THANK YOU
