2002 XLT little accident need help
02ex
york, PA
2002 Ford Explorer
Only my second post here because I haven't had any issues. With recent snow I had a run in with a bank and it messed my bumper cover up. Need to know best options to fix this. Tight on money now. Unemployed school student.
ponkotsu
Colorado Springs, CO
2005 Lincoln Aviator
For sure the local junkyard will be your cheapest options for new parts if you need them. Can you give more details? If you need to repaint small areas, do some web searching on how to repaint with a rattle can. You can do a surprisingly good job if you do it right.
Explorer0204
Upstate NY
04 Explorer XLT
This..
Pictures of the damage would be nice.
Now, a somewhat temporary but good solution for any cracked panels is using Gorilla Duct tape on the back side of the panel. If you use alcohol and clean the area really well and take your time applying it the stuff is really strong and will hold the bumper together for a year or 2 anyway until you can get some money for a new one. I know how it is man I am in the same spot and sometime you have to get innovative to get you by until some money comes rolling in.
D Cost of valve cover gasket on a 2002 XLT Stock 2002 - 2005 Explorers 8
M 2002 explorer xlt transfer case shield Stock 2002 - 2005 Explorers 4
S Understanding 4x4 Operation NonOperation 2002 XLT Stock 2002 - 2005 Explorers 19
R 2002 Ford Explorer XLT 4.0 Fuel Pump Replacement. Guide For Cutting Floor? Stock 2002 - 2005 Explorers 0
B 2002 Explorer XLt 4L 4x2 cranks but won't start Stock 2002 - 2005 Explorers 13
E 2002 Explorer XLT vehicle security module Stock 2002 - 2005 Explorers 5
E 2002 Explorer XLT power door locks Stock 2002 - 2005 Explorers 0
KA3NXN A few electrical oddities on my 2002 Explorer XLT Stock 2002 - 2005 Explorers 6
G Fixing-replacing all AC doors on a 2002 XLT Stock 2002 - 2005 Explorers 3
R 2002 XLT, Radio doesn't turn off when door locks. Stock 2002 - 2005 Explorers 1
L 2002 XLT rear window not going up Stock 2002 - 2005 Explorers 4
A 2002 Explorer XLT Wiper Problems Stock 2002 - 2005 Explorers 4
F 2002 Frod Explorer XLT 4x4 Stock 2002 - 2005 Explorers 2
F 2002 ford explorer XLT 4x4 no air will blow threw vents only threw defrost Stock 2002 - 2005 Explorers 2
A 2002 Explorer XLT 4.6L V8 4X4 won’t start Stock 2002 - 2005 Explorers 11
M 2002 XLT Rattle Fix? Stock 2002 - 2005 Explorers 2
L 2002 v8 XLT transmission servo bore issue Stock 2002 - 2005 Explorers 0
B Ford Explorer 2002 4.0 xlt hissing noise Solution Found Stock 2002 - 2005 Explorers 0
B 2002 Explorer XLT with significant body damage. want to buy a vehicle with blown motor and swap mine Stock 2002 - 2005 Explorers 1
G 2002 exploder xlt cold no start problem Stock 2002 - 2005 Explorers 27
V 2002 Ford Explorer XLT Rear Hatch Hinges Bent Stock 2002 - 2005 Explorers 0
T 2002 ford explorer xlt shifts hard into 2nd gear and od light flashing Stock 2002 - 2005 Explorers 25
J 2002 xlt 4.6 swap Stock 2002 - 2005 Explorers 1
B How many O2 sensors on a 2002 Explorer XLT? Stock 2002 - 2005 Explorers 1
L Question about 2003 XLT and 2002 Sport Compatibility Stock 2002 - 2005 Explorers 1
2 2002 Ford Explorer XLT 4x4 4.0L 6cyl->Where are the fuel injectors? Stock 2002 - 2005 Explorers 9
2 2002 Explorer XLT 4x4 4.0L 6Cyl-will start but almost immediately cuts off Stock 2002 - 2005 Explorers 9
2 2002 Ford Explorer 4x4 XLT 4.0L 6cyl SOHC->Engine not getting gas Stock 2002 - 2005 Explorers 6
M Rear aicon fitmemt to 2002 xlt Stock 2002 - 2005 Explorers 0
S 2002 Explorer XLT Cranks but won't start Stock 2002 - 2005 Explorers 27
P [Explorer XLT 2002 4.0 V6] Problem with engine start Stock 2002 - 2005 Explorers 4
K 2002 XLT 4.0 4WD 4D - Part out or salvage or ? Stock 2002 - 2005 Explorers 8
L slow drip around oil filter 2002 XLT v8 Stock 2002 - 2005 Explorers 5
G questions about wheels on 2002 Ford Explorer XLT 4x4 Stock 2002 - 2005 Explorers 10
J 2002 Explorer XLT growling from front Not the bearings Stock 2002 - 2005 Explorers 7
R I own a 2002 Ford Explorer XLT! Stock 2002 - 2005 Explorers 3
R 2002 XLT needs new battery... Stock 2002 - 2005 Explorers 8
2 2002 Explorer XLT Rear Window will not lock Stock 2002 - 2005 Explorers 7
M 2002 EB XLT..list of issues... Stock 2002 - 2005 Explorers 1
M 2002 Ford Explorer XLT P0775 error.. no check engine light Stock 2002 - 2005 Explorers 0
J Rear Passenger Wheel Binding 2002 Explorer XLT Stock 2002 - 2005 Explorers 4
R 2002 ford explorer xlt code PO231 Stock 2002 - 2005 Explorers 3
E Need help replacing Both Low Rear control Arm Bushings! 2002 Ford Explorer XLT Stock 2002 - 2005 Explorers 1
6 2002 XLT won't stay running Stock 2002 - 2005 Explorers 3
C help with 2002 explorer xlt Stock 2002 - 2005 Explorers 0
K 2002 Ford Explorer XLT Spark Plugs Question Stock 2002 - 2005 Explorers 4
S 05/01 (2002) XLT 4.0 leaking coolant under driverside Stock 2002 - 2005 Explorers 4
R will 2003 instument pane work in 2002 explorer xlt? Stock 2002 - 2005 Explorers 1
R will 2003 EB Explorer windshield fit a 2002 xlt? Stock 2002 - 2005 Explorers 2
V 2002 XLT 4.6L misfires and leaking coolant Stock 2002 - 2005 Explorers 3
Similar threads
