kammy
- August 9, 2016
- cloudcroft NM
- 2003 Explorer
Went to do a normal oil change.2003 4.0 ltr Pulled the plug, filter and let it drain. Put the new filter on, after the oil quit running out I reinstalled the plug and poured 5qts of oil in. This is where it gets weird....pulling the dip stick, it was way over full, checking what came out, 2 qts. So I pulled the plug to empty more out......nothing.....stuck my finger in the filler hole, no oil pooling there, stuck a screw driver several inches into the oil pan and nothing either. Dipstick says over full, pan says empty, oil pressure gauge reads "normal".
