2012 Explorer Gas Pedal Vibration Update
Here is the fix for my 2012 Explorer gas pedal vibration.
18 days in the shop to fix this.
It ended up being fixed by adding another hold down or clamp to the shifter cable that runs from the gear shift lever inside of the Explorer to the engine compartment through the firewall next to the gas pedal. The hold down or clamp was added to the cable before it went through the firewall (there were already two on it).
If you have a 2012 Explorer with a gas pedal vibration (feels like an electric razor buzzing under your foot) then this may be the fix for you.
PM me if you would like your dealer to speak with mine on what he did to fix mine.
This was also the fix for other Ford vehicles that had the same gas pedal vibration and even has a part number that dates back to 2006.
The fix that works on 2011 Explorer gas pedal vibration may be the one I just explained or it may be what fixed another one I learned about during all this.
The 2011 Explorers have their Brake line cluster that runs from the HCU (Hydraulic Control Unit - controls ABS braking) next to the transmission lines that then cause the vibration. This was fixed in the 2012 Explorers by Ford moving the components further away from each other.
Next issue on my new 2012 Explorer that should not be happening.
This was happening before I took it in for service on the gas pedal vibration.
I have a whine or hum that happens under light acceleration and will stay constant after approx 45 MPH and will do it mostly at highway speeds.
This started intermittently around 3000 miles and currently I have 3450 miles on it.
This whine or hum ONLY happens when pressing the gas pedal.
As soon as I take my foot off the gas pedal it will stop almost instantly and start back up once I press the gas pedal again. (Usually 45mph to 55mph range)
Does NOT do it while coasting or braking.
Anyone else have a 2012 Explorer V6 with Tow package that has this whine or hum while pressing gas pedal and stops after releasing the gas pedal?
Please list vehicle specs when replying to help narrow this down.
If so anyone have the fix?
Thanks
Nexus
