Nexus
- October 19, 2011
- 2012 Explorer
RandyH2: What does the dealer think yours could be?That's a bummer.
I wonder if there could be a bad engine/transmission mount or something similar which was causing the vibration which is transmitted by the throttle cable to the pedal. They clamped it down better to reduce/eliminate the vibration but maybe that failed, or caused a failure elsewhere.
Mine still vibrates. I've trained myself to ignore it, mostly, until the MFT really angers me and then I think, "This POS still vibrates... I hate Ford for pretending the problem isn't a problem! Argh!"
Remember when you asked if mine vibrated while holding my foot on the brake and keeping the engine at 2000RPM? At the time the vibration was not that bad for me just a bit excessive, now it vibrates doing that way more than it should.
I dropped my 2012 Explorer off on (12/22/11).
My service manager is really nice thank goodness.
He also got me a 2010 Explorer 4WD as my rental Which is ironic since it is almost identical to the one that Ford replaced for me under the Ohio lemon law for this 2012 Explorer I am now fighting with (For details read my previous posts).
I am pretty sure that this will be an unsolvable mystery and I will be spending many hours in travel time back and forth to the dealer and probably many months talking on the phone to Ford and the dealer (and losing money at work - I already did that this year from January to August for my 2010).
After which point I will have to pursue the Lemon Law AGAIN to replace this second Explorer in the string of problem vehicles I have gotten from Ford since 2010 (I refused a 2011 Explorer because it had a long 5 inch flaw in the paint under the clear coat on the driver side fender and on the rear hatch a big spiky blob of paint - should NOT have passed quality control).
After only buying Fords my whole life I think I am done.
After speaking with many sources over the last year I learned a lot about Ford.
Did you know that Ford will not let a dealer fix something even if the dealer KNOWS that it is the problem without first reproducing the issue (from what I have been told)? They can't even take a vehicle apart without permission now to try to diagnose it unless they can prove that taking it apart is needed to fix the issue (from what I have been told). That is why (I believe) none of the vibration issues will be fixed because Ford will not give permission to the dealers to do whatever it takes to fix the issue so the dealer is stuck in the middle unless they can prove what it is.
So far my Service manger and two engineers from Detroit (who drove to the dealer) have physically worked on this for many hours at the same time together and no one has a clue what it could be (not allowed to take things apart though because they can't pinpoint the issue). Ford also has a research tech group in Detroit who spent 2 whole weeks sifting through notes from other dealers and engineers and they could not come up with any answer to what this could be.
Merry Christmas everyone!
Maybe Santa will bring me ANOTHER replacement Explorer to replace this bad one.
I used to enjoy seeing Mike Rowe on TV but now not so much anymore when doing the Ford promos - reminds me of this past year fighting with Ford on my 2010 EX and now my 2012 EX!
Just kidding Mike I do enjoy Dirty Jobs though!
