KayGee
- March 27, 2017
- Farmington, MI
- '16 & '17 PIU
Post your 2016-18 Police Utility Forscan settings here.
Enable RKE
720-02-01 xxxx xxxx xCxx - RKE menu in IPC
726-38-01 x1xx xxxx xxxx
726-41-01 xxx4 xxxx xxxx
This is just to enable the full RKE functionality on the vehicle - There are 2 different fobs for 16+ PIUs (blue button for hatch or red button for panic - about $30-40 each) and in order to get the fobs to work, they will need to be programmed to the vehicle in IDS (check with your local dealer for cost).
Liftgate
726-37-02 x1xx xxxx xxxx Police Rear Door Config - enable overhead liftgate button/timer
726-37-02 x0xx xxxx xxxx liftgate will lock/unlock with door locks - disables overhead liftgate button and liftgate timer
Seatbelt minder
720-01-01 xxxx xx6x xxxx both on
_________xxxx xx2x xxxx driver off
_________xxxx xx4x xxxx passenger off
_________xxxx xx0x xxxx both off
AWD gauge cluster
720-01-01 xxxx x2xx xxxx
Dark Car/Silent Mode/Courtesy Lamp Disable
720-04-01 xxx4 xxxx xxxx this allows control in IPC menu (I believe this only works with PIU/base IPC)
726-32-01 xxxx x1xx xxxx activates the option
726-58-02 xxxx xxxx x1xx - IPC menu will toggle this from 1 enabled to 0 disabled (or you can set it yourself to enable feature if your IPC doesn't support the menu option)
Turn signal flashes - Partial list below - more available elsewhere if you want different # of flashes
724-01-01 xxxx x6xx xx 3 flashes
_________xxxx x8xx xx 4 flashes
_________xxxx xAxx xx 5 flashes
DRL
horn feedback on locking
726-38-02 xxx1 xxxx xxxx enable
_________xxx0 xxxx xxxx disable
light feedback on locking
726-56-01 xxxx xxxx x1xx enable
726-56-02 xxxx xxx1 xxxx enable
726-56-01 xxxx xxxx x0xx disable
726-56-02 xxxx xxx0 xxxx disable
disable key left in ignition warning chime
720-02-01 xx#x xxxx xxxx disable (subtract 8 from your current value for #)
12v powerpoint timeout
726-39-01 #### xxxx xxxx - #### is hex value for time on (ex. 1194 = 1hr 15 min, 012C = 5 min, 0001 = on/off with vehicle)
Right half of IPC display can show AUX switch status or vehicle image
720-04-02 xxxx 6xxx display AUX switch status
720-04-02 xxxx 4xxx display vehicle image
Disclaimer - this information is being provided for educational/entertainment purposes only - use it at your own risk
Enable RKE
Liftgate
Seatbelt minder
AWD gauge cluster
DRL
