Add Fog Light Indicator?
bt1987
Columbus, OH
2014 Ford PIU
I have been doing lots of research on the Fog Lights in the 11-15 Explorers, and I have found an option to enable the Fog Light indicator on the dash. The information I have states the following:
IPC 720-01-02
xxxx x8xx xxzz to enable the Fog Light Indicator
xxxx x0xx xxzz to disable the Fog Light Indicator
Well that doesn't work on the PIU... The bit at that address, when increased to 8 (or anything other than 0) gives me error messages about Collision Avoidance, Blind Spot Monitoring, etc.
Who has successfully activated the Fog Light dash indicator on a PIU? I suppose I could continue doing what I was doing to enable Remote Start and the Locks Menu. The information online for Remote Start says to use C8F3 to enable the Remote Start menu. That absolutely doesn't work for the 2014 PIU. I had to go bit by bit and compile a chart to see what the options were, and came up with 80EA in order to add the Locks menu (my default was 800A). Then to add remote start, I had to move to the next address. The second block, originally 0000, I had to go through and change to 00C0 to activate the Remote Start. So clearly, I've had to completely change two blocks of data instead of one, and the one I changed was nothing like what was suggested.
Does anyone have the code to activate the Fog Light indicator? Thanks
Hallandry
Aurora, co
2017, Explorer, PIU
Set it to 1, not 8
720-01-02 xxxx *xxx
Forward Collision Warning (FCW), FFV, Front Fog Lamp Indicator (FF)
0=FCW none, FFV disabled, FF disabled
8=FCW FCW+FDA, FFV disabled, FF disabled
1=FCW none, FFV disabled, FF enabled
9=FCW FCW+FDA, FFV disabled, FF enabled
2=FCW none, FFV enabled, FF disabled
A=FCW FCW+FDA, FFV enabled, FF disabled
3=FCW none, FFV enabled, FF enabled
B=FCW FCW+FDA, FFV enabled, FF enabled
4=FCW FCW, FFV disabled, FF disabled
C=FCW Truck FCW, FFV disabled, FF disabled
5=FCW FCW, FFV disabled, FF enabled
D=FCW Truck FCW, FFV disabled, FF enabled
6=FCW FCW, FFV enabled, FF disabled
E=FCW Truck FCW, FFV enabled, FF disabled
7=FCW FCW, FFV enabled, FF enabled
F=FCW Truck FCW, FFV enabled, FF enabled
bt1987
Columbus, OH
2014 Ford PIU
Set it to 1, not 8
720-01-02 xxxx *xxx
Unfortunately that didn't work, as I have a 2014 PIU.
However, I had some time today to sit and flip bits. I've just about found everything possible on the IPC at this rate.
I found the Fog Light Indicator on the 2014 PIU finally. It is located at 720-01-01: xxxx xxx* xxzz.
The full rundown of 720-01-01 xxxx xxx* xxzz:
0-1, 8-9 - No Fog Lamp, No TPMS
2-3, A-B - TPMS
4-5, C-D - Fog Light Indicator
6-7, E-F - TPMS, Fog Light Indicator.
