What size?I I used a big Allen wrench
Ok ill go buy a big setIdk big
Ok thanks bro ill go and get someI think it was a 10 mm but don't kno for sure
get it after the nader watch buddy!!! not before/during.Ok thanks bro ill go and get some
But is it English or Metric size??Ok ill go buy a big set
Nah let's do it while the nader is spinning overhead YEEYEEget it after the nader watch buddy!!! not before/during.
That i don't knowBut is it English or Metric size??
na dont do it!! dont do it!Nah let's do it while the nader is spinning overhead YEEYEE
Lolna dont do it!! dont do it!
Same here on my 2001 ST. Worth every penny. You get what you pay for.I've got 3-years on the Simmons Autosport housing (2010 Explorer) and about 50k miles. No problems, no regrets.
What did you use on the thread in barb for the heater pipe? i used thread tape and its leaking stillI think it was a 10 mm but don't kno for sure
ok i didn't know if it would hurt but that is where its spraying out at.I used gray rtv on everything
Will doClean the shi* out of it first !!!!!
Not sure if anyone noticed or posted seeing the aluminum & metal thermostat housings now available on RockAuto, from Dorman (metal) and SKP (aluminum). They were available under the 2 years I looked up 2002 & 2008. Didn't see it posted on here & just thought I'd let anyone know looking into the plastic-to-metal swap that there's another option out there to look at...
Can you scroll thru RockAuto and post up the page with the metal/cast unit the two-sensor version?
Sadly I replaced mine with a Motorcraft version back in 2018 when I did the water-pump & now I see the bottom half has spider-cracking somewhere is changing a shade-of-black indicating it might start to leak... again!
