410Custom's builds a 2007 Ranger V8 - custom truck build - Project "Ranger Premier" | Page 41 | Ford Explorer Forums
OK, I'm back to 28 so far..
Edited: found it
So is the 185 degrees before TDC for the crank sensor? unique to the Holley system?
Yes unique to Holley, it is for the cam sensor not crank.
Basically it is how we get the ford cam synchro to work with the Holley pcm
With engine at tdc (cyl 1 compression stroke) then brought around so the crank damper is at 185 degrees before top dead center , the synchronizer is stabbed and cam sensor aligned
Post #502 is the start of 02 sensor bung install
Post in thread '410Custom's builds a 2007 Ranger V8 - custom truck build - Project "Ranger Premier"'
Page 31 for me
Cam sensor, I see. I look back and am still amazed how involved mentally, physically and time wise. :thumbsup:
Wait until you see the console and seats
After I sorted out the passenger seat it Took over a week to get the drivers seat to fit properly
It came out that is for sure, which is good because the way the drivers seat was before was unacceptable. I was even seat shopping just in case this was impossible. Had a line on some 2011 ranger seats but the dude wanted too much. I am super relieved that I was able to make these work…. And work they do!!!
One of the best conversions I have ever done, but it has its moments hahahahaha
Losing sleep over drivers seat fitment has me battling to win this war
Seat retrofit with console was about as much work as converting to v8 lol
Well done Jamie, that's all great work.
What kind of device might it take to alter the Canbus cluster functions, if you know? I like the 7k tach but might want a speedometer a hair higher than 120, and the older clusters are starting to become flaky/glitchy etc.
I have plans to add LED readouts within each of the smaller gauges, but hadn't planned any other major changes. I'd love to find that the Mongoose Plus can alter the cluster in some way, all I know of it so far is that it's for updating late model Fords, and doing the tuning/programming communications.
I think I learned recently that the drive-by-wire(DBW) Fords have the cruise control functions in the PCM, that's a guess though. I need to find a DBW throttle body to bolt onto the 302 elbow, and the matching gas pedal.
I hope that console work turns out great for that 07 Ranger. I'm interested in how it may be possible to mount a similar shifter(none with the shift button on it for 6R transmissions) in my 98 console.
i will say the terminator system i am trying to do got the best of me. i had to send it out to jamie, then a second guy to figure it out! and jamie is doing way more then what i am doing. i dont know how he hasnt wound up in a asylum!
jamie, for the speedo, you might know this, or might not but i found this a while back when i was messing around with my cluster.
not sure if it will work for you because its a older cluster. all i know is that it beat driving down the road trying to read a gps, set the cruise, then trying to stab the needle in all while doing 60mph. what could possibly go wrong doing it that way?
There are can bus emulators for
Clusters available now, on eBay you can purchase a 2014 mustang gauge cluster desk art and you can control over some of the functions so people are on it…. That’s about as far as I got in my research before I discovered I could use 05 cluster still has 14 wires for indicators, signals and warnings
The one problem I do have is the milage goes w the cluster = this one reads 253,x.. this truck has half that
Can the cluster be reprogrammed?
I was at a custom speedo shop getting a new speedo cable made for the Explorer after installing the Atlas. There were several instrument clusters they had rebuilt. I asked how they got the clear plastic to look like new. They buy the cheapest headlight cleaning kits they can get from Walmart, then use plastic wax to finish them. I did that on mine, it looks like new and it's been a few years.
Love this, Thanks!
I can't lie, I'm losing sleep over that type of SHAG shop rag. At first I suspected 3 types, but now have ruled out frieze, and random, and settled on it being saxony 😈
Love this, Thanks!
Shag and sexony go together in the same sentence.
All right here we go..... the seats
We all know I installed the drivers seat, 2014 Ford Edge 6 way power w heat
chopped up some ranger seat rails for the mounting "feet" and integrated them into the base of the 14 "edge" seat
I retained all 6 way power functions the result was a seat that sat too high off the floor for a ranger cab
It has been bugging me ever since
So when it came time to install the passenger seat I had some ideas
It turns out, they worked like a charm
I was able to install the seat on the ranger manual slider rails, and lower the seat significantly vs the driver side
This lead to a total re visit of the drivers seat install.........
Battle on
First up....the passenger side
Starting with a factory ranger manual slider. Base
This would get heavily modified
Donor rails Came from a 98-2000 ranger 60/40 front bench
Slider rails were shaved down and new mounts were added so they work in conjunction with the power functions of the 14 edge seat.
Sliding forward and back is done like a factory ranger seat, with the manual slider bar, spring assist.
The ranger base rails were mounted off center under the seat now, this allowed me to drop the seat another 1.5-2" vs previous power forward and back setup
The results are awesome
During fab and mock up
All 4 factory bolt holes are retained
Rails were modified heavily (lots of cutting, mount fab, trial and error, fit and chop cut weld..... until we have a bolt in seat fits and functions like factory
Manual slider bar just like stock ranger
down low and back
Lots of adjustability now
Power recline, power lumbar support, power front tilt and power rear tilt were retained.
Heated base and back was also retained
Now wired in! I am in the process of mounting switches and relays
way lower then drivers side
Time to re visit the drivers seat
The drivers seat was then also mounted on a manual slider, lowered an additional 2" and set back a bit. I documented that full build
The drivers was much more involved then the passenger side
While the seats were in and out I also mounted the console shifter. Shifter park shift interlock, illumination and OD cancel buttons were final wired
The Holley PCM final mounting location was also decided. I built a weather tight floor plate with wiring and shift cable pass through
2008 Mercury mariner center console was fabricated to fit our ranger and between the seats.
Mounts were created, console, shifter Holley and all wiring are in. wait until you see how this turned out!
I added custom touches along the way, of course
Next up the drivers seat re do
okay I documented the whole build of the drivers seat, so there are alot of pictures.
There was ALOT of trial and error, putting the seat in taking it back out etc etc to get this right!
End result is seat is centered, as far down as possible, as far back as possible, retains 4 of the "6 way power" functions, the seat is mounted to factory manual slider for forward and back movement. Factory heat is retained and wired up, also the lumbar support and power recline backrest all function like a factory seat.
The first attempt had the seat sitting too high in the cab
The 2014 Edge power "rails" had to go
So first I needed donor parts, 2000 Ranger 60/40 bench, drivers sliders were removed
Now the factory rails get “shaved” with a grinder.
Basically the only thing I keep is the slider and the slider actuator rod and all 4 “feet”
More parts removed
Keep all hardware and the spring for later use
This is the 2014 edge power seat rail assembly from my first attempt. The structure is too tall and too wide for our ranger floor pans
Time to get to grinding. I stocked up on cutoff wheels for this job
Plasma cutter could work as well but I did not want all the slag cleanup later
This is the passenger seat, it has been completed already. We have a similar goal for the drivers seat here
On the bottom of the 14 edge seats there are 4 mounting studs where the pivots take place for the front and rear “height” motors. These 4 studs will be the mounting locations for our new ranger manual slider rails
Previously the seat was mounted on top of the power sliders. My idea to lower the seats was to mount the manual slider rails off to the sides.
It works!
But not without some headaches
Pass seat seen here you can see the slider rails and how they are
Mounted.
So first up I need to press the little studs out of the seat base so they can be flipped around and welded to the ranger sliders
Drivers seat no rails no studs ready for new parts…. Well kinda
So now we need to finish prepping the ranger slider rails
Most everything shaved off the top
Grinder got a nice workout all week
Houston we have a problem. The inner slider (console side) needs to go right where this front height motor exists. Crap!!
Huge roadblock
Many hours later my brain hurts but I had another idea. After much measuring and calculations I decided I could relocate this
Motor to the middle out of my way
I cut the motor off at its
Mount. I would Re use this part of the mount. I also had to chop off the strong arm where it attaches in order to rotate the front pivot bar
The motor and it’s mounts
Now I had to figure out how to re mount it in the middle of the seat. I would have to create a new crossmember
Add mount and clearance for motor angle
Welded to the old mount and both crossbars
Braced for strength. The strong arm pivot needed re located on its pivot bar (axle) so I made a fixture to retain strength
Paint over the welds and mount the motor. Works like a champ!
now to fabricate and mount the new manual sliders
This is where the inner rail needs to live, exactly where our old motor was.
Plenty of clearance now
Inner rail getting final prep
This is how the mounting studs will go, prepped and clean ready for welding
Welded 1/2” at time to avoid overheat and warping of the rails
All 4 studs mounted and measurements clearance checked
The neat part is the rails even though they are off to the sides and offset from center of the seat they are still correct distance apart for the factory slider activator bar!!
Rails final welded and ready
This is how it fits, plenty of room for motor and rails. However the activator bar hits one of our front pivots and the seat still sits way too high
Well done.
edit, I thought those were 8.8 cross shaft bolts, I see the heads are Torx now. I replace the 8.8 cross shaft bolts every time I take one out.
not done yet!! still have some clearance issues, seat is now 2" off center and sits 1.5" too high. Getting closer
Now this next part I have actually done a few times putting explorers seats into rangers I often have to remove 1.5” from the height of the ranger sliders
Bolt Holes off center
Time to chop 1.5” out of all 4 feet
I use marks to keep things lined up once 1.5” of material is removed
New dropped feet and new bolt mount tabs being fabbed, tack welded and checked for alignment and fit
Chopping the other rail
The pieces that were cut out are used to re enforce each mount
Final test fit, mounting holes lined up to center seat and retain factory
Mounting locations
Test fit time!
Happy! Shhhhhh pretend you did not see the console and shifter yet
Seat removed again for final clearancing/ paint/ weld etx
Problem area
My brain came up w another solution. I flattened the round bar in the press at the correct location and re bent for clearance. Then I used two small sections of angle iron to zig zag for
Clearance
It friggin worked!!
Now seat removed again for final paint, clean, lube, and wiring
Added 8 pin connectors for both seats. Wired new power feeds for seat power and seat heat direct from fuse box under hood. Also included are seat buckle switch wires
Final prep and paint complete the drivers seat is nearly done!!
Very nice work. What is the large module for, did it have side airbags too? I like the separate motor locations, that makes it easier to place them or have them take up less space.
I have a NOS Continental seat track which has memory seat motors in it, but the entire assembly is much different than the cousin Mark VII that I'm planning to install it into. I haven't begun to find out if the track will come close to fitting my floor mounts, thus no clue yet what it will take to make it work.
Looking good. We need hands free cameras on our hats for documentation. Sort of like the cop cams on their chest...
