- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
that is the memory seat module it also has the power and heat functions travel through it so I had to retain it on the drivers side. The 14 edge donor came with 6 way power heated seats, drivers memory
If it was a Lincoln mdx they had 10 way power climate seats, still a very Similar seat.
These seats are can bus
I used a series of relays on this truck for the heated backs and butts
Simple push button heat is on until you turn it off.
My 97 f350 has Lincoln heated and cooled seats, in that’s truck I used relays and 7 pole switches to reverse polarity for the heat and cool functions.
We could also use the stand alone seat climate control modules from say an Escape or superduty here to control the seats.
In the seat donor “edge” the dash mounted hvac controls also controlled the seat heat and I believe the memory seat switch also in the dash or door panel.. those parts I do not have.
With just heated pads I kept this truck simple. Button on = heat. No timer no low and high settings.. these could be added later. I researched the heck out of this
There are some utv seat heater kits cheap enough with high and low settings, some have 6 way heat adjustment, but nothing with a timer or thermostat
I am thrilled to have two working seats like we intended… the manual sliders are better anyways otherwise you gotta sit there and wait for it to move to get in the back. I had power sliders in my bii and eventually converted back to manual lol
Next I will cover all the wiring I have done for the seats as well as the console install , shifter, and Holley pcm wire and mounting
I’m very pleased with how this came out, really updated the older ranger interior and it’s super comfortable
