410Custom's builds a 2007 Ranger V8 - custom truck build - Project "Ranger Premier" | Page 40 | Ford Explorer - Ford Ranger Forums - Serious Explorations
now I feel bad. The 1 ton hasn't moved for a couple weeks, time to take em on a tour..........
All right so the last time we saw the truck it was running, shifting and had brakes!
Instrument cluster mostly working as well.
Nobody in the videos pointed out that the cruise control had been re located, and the arb pump was in place,
lights in the bumper, .... and the truck obviously has driveshafts and more
you guys maybe slippin!
HAHAHAHA
Anyways it has been a long hard few weeks, most of the time was spent on the seats and console install........
Lets check it out
I will start with the instrument cluster:
In order to get a working speedometer I needed to install the Dakota Digital speedometer interface.
Really easy to wire up after you have done a few of these.
Basically Dakota Digital (DD) gets its input speed signal from the VSS in the rear axle. The VSS sensor in the rear end is a reliable place to take a reading.
The VSS wires from the rear axle speed sensor head directly to the 4WABS control module under the hood. This is true for most 98-11 Rangers, Explorers, etc
The ABS module then processes this signal and sends it on to many systems in the truck.
However the speedometer and cruise control use a different signal
The old 2007 PCM from the SOHC engine would have done the speed signal "buffering" for the speedometer and cruise.
Traditionally ford speedometers need to see 8000 pulses per mile, this 05 cluster is no different.
Wiring the Dakota SGI 100BT
I get my rear axle VSS signal + wire at the ABS pump. I only need to run this one wire into the dash
07 ranger the wire is white/black
I soldered a brown wire to the rear axle VSS + and used a pass through from a 05 Ranger to get some wires through the dash cleanly
I needed to run tachometer signal from Holley to the cluster, reverse light feed into the interior and a few others
The Dakota box gets 4 wires total on this truck
1. ACC power on (BLUE hot in start and run) taken from ignition switch
2. Ground BLACK chassis ground right near e brake pedal
3. VSS + in (BROWN from our ABS motor turns to red/white inside near cluster)
4. Buffered VSS signal out (WHITE direct to 05 cluster, speedometer in and cruise control) This wire is hooked to OUTPUT 3 for our use, explained below
Much time spent finding the perfect mounting location and fabricating mounts for these electronics
This is the perfect place to put this in a late model Ranger, the old fuse box cover, Thanks Ford for keeping this cover even after the fuse box went MIA in 2002. The dakota is adjusted while driving using two buttons on the faceplate, or while idling, and it can also be adjusted via bluetooth with the Dakota app (can be installed on Android stereo/ head unit)
I have already set a few of these up in our trucks. I copied and pasted the setup instructions from another thread:
Now you need to setup your Dakota box so it will work for us with application 3
referring to the instructions found here: https://www.dakotadigital.com/pdf/sgi-100BT.pdf
Set the Dakota box to convert a high signal to a low signal (H-L) or application 3
Any signal over 32000 ppm is considered a HIGH signal (for us its 77,760ppm)
Any signal under 32000 is considered a LOW signal (for us the target is 8000ppm)
Application 3 settings seen here:
Set the CAL value to 1.65
Using output 3 will send 1/16 of that value to the black/grey 679 vss+ signal to modules.
The math goes like this:
Figuring out the VSS PPM:
Tire revolutions per mile x ring gear teeth = VSS generated signal to ABS pump
29" tire revolves 720 times in a mile
Our 8.8 ring gear has 108 teeth, so
720 x 108 = 77,760 pulses per mile (ppm)
being sent to the ABS motor from the rear axle VSS
77,760 needs to be factored up so that 1/16 of it is close to the target 8000ppm.
(1/16 of something is the same as saying multiply by 0.0625)
So
(77,760 x __________ ) x 0.0625 = 8000
77760 x 1.65 = 128,304
128,304 x 0.0625 = 8019 pretty dang close
Can also say it like this:
1/16 of 128,304 = 8019 PPM
That is how we get our CAL value of 1.65 and know we need to use output3 which is 1/16 of that value
This will give us a working speedometer that can be adjusted for larger tires, gearing changes, changes in pressure as you go!!
Now I spent ALOT of time looking for the perfect location for the ARB locker air compressor
I have had one of these (older version) under the hood of my BII since 1999 or so?? It still works like new to this day/. My wifes FJ cruiser also mounted compressor under the hood. Under the hood works it keeps them out of the elements cuts down on the noise and makes for a cleaner install w all the wiring and plumbing following factory routes. Also closer to the power distribution and dash for the switches.
I wanted to put it under the hood for sure. Other options were under the truck, behind the grill, and a few others I looked at.
I finally decided to keep it simple
found a perfect location for the cruise control and used the factory cruise control bracket (or two) to mount things
ARB system wiring harness mounted in truck and ran
ARB HO Air compressor, factory mounting brackets are very nice, lots of ways to rotate and move things around to suit your needs
This is where I want the compressor to land
factory cruise control hanger melded w arb compressor mount
mounts with one bolt
The main fuse for the arb system easily accessed
Compressor mounted
Now the cruise control will need a bracket
I used a second factory cruise mount to make this so
Drilled one hole in truck
Clears the hood hinge cable and all wiring reaches no problem, perfect!!
*cough tachometer cough*
The tachometer works? Hooks up directly to wire from Holley
I show it working in the videos silly
i knew it worked, i did see it in the video lol. what i didnt know was how you got it to work.
Sure man I will show you how I wired the tachometer!!
My chicken scratch notes from measuring for shafts. I
Love posting this behind the scenes stuff
Lets check out the driveshafts
I scored on some 1997 F1250 driveshafts locally
I shortened them and rebuilt with new U joints
Front
All parts kept in phase and square during re assembly
Beware the pink work bench towel!! Maybe hard for some viewers to see
Moog conversion u joint, they did not have a spicer conversion joint in town. Moog will work
Any “high welds” were knocked down with grinder. shafts cleaned, painted, assembled. The big metal “ring” on the rear shaft was removed (with torch) for clearance of the ranger crossmember
Done!!
No! If it need balancing then we can have it done. Shafts were balanced before I get them, as long as we keep them in phase and square I have not had an issue with like the last 4-5 trucks I have done. They are all still on the road. The “driveline” shop I used to pay to do this for me ($400-600+ now??)! They don’t even balance them either… I figured I could do a better job myself and save the money. So far I have been right!
We did find a driveshaft shop about 2 hour drive he is willing to help us for a fair price and he can balance. I’m happy with this method so far. There are some YouTube’s that show us how to redneck balance if there ends up being a wobble (there won’t)
The instrument cluster
Now that I have a working 2005 cluster I wanted to make it appear to be his original 07 cluster with the white faces
So I took both clusters apart and swapped the good looking parts over
Everything cleaned and dusted ready for assembly. The needles are only pressed on lightly because they will need adjusting when power is applied
Much better to have a nice clean cluster
I really like these late model units, the 2005 is the last year with wiring inputs, after this they all went can bus and we will need some sort of can bus emulator to make customizations to any of the gauges or warning lights
Did you fork the needles to get them off?
Where would I find the picture/s of the 02 bung location?
Yes you can see the fork in the pictures. These late model needles take ALOT more force to remove then the old ones I was worried the first time I was going to break something pulling really hard.
The 02 sensor bung is back a few pages lol lol I’ll show you
