- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I'm sorry to see this problem, but it's good you found it, and it might be an easy fix. I'm headed to bed just now, but let me guess it needs a good bit shorter pushrod. I didn't recall it had the stock rockers, I figured they were adjustable rollers.
Stock rockers have a certain limit of valve lift before the pushrods might touch, different for any engine. What is the cam lift, I'd expect most OEM pedestal rockers would be near their limits in the .550" range? The bigger cam lift is pushing up a lot more than stock(guess at about .450" for most stock cams). So the valve has to go down that much more, ... compare the lift of the truck roller cam to the new cam. I hope you work it out quickly. Night,
edit, I removed the mentioning I had about changing the pushrod length to below the stock length, that was for dealing with adjustable rockers. I'd begin again with the stock length using an adjustable pushrod.
